Will not go faster than 30 miles per hr. Seems like it is running out of gas. Changed fuel filter. looks like you can see air bubbles in the fuel filter while driving it. Any ideas? Used fuel filter from Kragan that fit the lines. Do you have to use Yamaha fuel filter?
Yamaha 95 wave venture 1100
Re: Yamaha 95 wave venture 1100
The yamaha fuel filter may flow better than an auto filter, I know on the sea-doos the auto ones dont work well. You also have internal fuel filters in side the carbs that may be plugged up, take them out and inspect them.SBT Tech Support is here to help with your problems.
Originally posted by Mikeboettcher53 View PostWill not go faster than 30 miles per hr. Seems like it is running out of gas. Changed fuel filter. looks like you can see air bubbles in the fuel filter while driving it. Any ideas? Used fuel filter from Kragan that fit the lines. Do you have to use Yamaha fuel filter?
You may also want to inspect the fuel valve i have seen these go bad but not to much on Yamaha's but it happens. james** Is your engine core wasted send me a pm I may have the core you need to send to SBT **
