Ok so I replace the coil pack due to #3 wire getting no spark. Problem fixed! Then I drive to the lake and put the ski in the water. Now it decides its not going to go past 20mph. I get back to the dock and pop open the hull and smokes just rolls out of the hull. I look noticed that the rear seal where the drive shaft comes outta the case has blown out. The ? is how does that shaft come out to replace that seal? Any help would be greatly appreciated.
96 Waveraider 1100. Seal replacement how to!!
