My Waverunner stalled on me while running full throttle twice. The second time I was able to get it started and running long enough to get me back to the marina and on the trailer.
The local Yamaha mechanic showed me that 2 of the 3 cylinders had really low compression. 80 and less than 25 in the #2 and #3 cylinders. He suspected that the cylinders were etched.
I'm planning to inspect the cylinders and pistons, then will order a top end kit to replace the cylinders and pistons. My question is, do I have to remove the engine to make the change?
When the ski was running, I heard a lot of rattling of the impeller, but it ran fine. Does the rattling indicate worn drive shaft bearings? Can I change those without removing the engine as well?
Thanks for your help!
Chris
Chris
