i have an 02 gp1200r one cylinder is bad bc lack of oil to that cylinder. I was wondering if i can sleeve that cylinder and just replace the piston rings ect.. or will i need to do the other two also?? i already have a new piston .5 over. is it ok to use that one or should i return it for a stock size piston..thanks in advance
gp1200 cylinder sleeve question
Re: gp1200 cylinder sleeve question
What's my best option? What will a new cylinder cost from u guys I have the old one to use as a core. And if I get a new cylinder from u guys can I use the. 5 over piston I have or should I return it for a stock piston.
And is it OK to have one piston bigger than the other two. Just.
5 over sbt piston
