Hey guys, hate to ask this again but I just needed some info, I experienced a problem a year ago where the screw holding the powervalve came loose causing the the powervalve to slam into the piston, just two questions, I remember one of the techs saying that sbt has something to block the valve from ever making it way to the piston also do you recommend Loc Tite on this screw so it doesnt happen again. thanks for any help you can provide
Yamaha Power valve question
Re: Yamaha Power valve question
SBT makes a keeper to hold the pin in at the top of the power valve shaft, in the past these pins would work free and drop the power valve onto the piston. Red loctite works well on the set screwsSBT Tech Support is here to help with your problems.
