When I pulled the flywheel cover off, I noticed the magnets and other stuff inside the flywheel cover looked pretty oily/dirty. What is the procedure and what do you use to clean the inside of the flywheel cover?
Magneto flywheel cleaning: 65U non-pv 1200cc
Re: Magneto flywheel cleaning: 65U non-pv 1200cc
I use the parts washer fluid to clean all the components on the engine including the magneto, any type of kerosene or degreaser should work fine.SBT Tech Support is here to help with your problems.
