Hey guys,
To start off I have downloaded and read every document I could find related to tuning carbs. Here is where I need help.
I just rebuilt my 2 Mikuni 38's.
My current settings are as follows:
Carb1:
NV 1.5
Jet Low: 67.5
Jet High: 120
spring: dull silver
Carb 2 (PTO):
NV 1.5
Jet Low 67.5
Jet High 130
spring: dull silver
My issue is that the pop off pressure on both carbs with the dull silver spring is around 22psi. I tried the shiny silver spring and the pop off pressure jumps to 42psi.
There is no leak and the pressure holds fine. I checked the NV to make sure the tip wasnt messed up.
What is puzzling me is that the shiny silver spring is supposed to be 65 g and the dull silver 95 g. Also the shiny silver spring is longer than the dull silver.
How come with a lower gram spring my pop off pressure is higher? shouldnt it be lower?
Left spring is the dull silver and right spring is the shiny silver.
This engine is totally stock except for FA's.
Thanks,
Tman
Carb1:
NV 1.5
Jet Low: 67.5
Jet High: 120
spring: dull silver
Carb 2 (PTO):
NV 1.5
Jet Low 67.5
Jet High 130
spring: dull silver
Thanks,
Tman
