just picked up a 99 1200 suv, the tube that is supposed to go from the nozzle to the transom assembly on the left side is missing, what is it for and what does it do?
tube on left side of jet drive.99 suv
Re: tube on left side of jet drive.99 suv
If the tube you are referring to is the rear water spout tube mounted thru the back deck of the ski, then someone has removed it because of the annoying issue it creates. Anytime some one else is following behind your ski they are getting sprayed by your water pisser.SBT Tech Support is here to help with your problems.
