Was just wondering if the replacement can be done in the hull and if so what are the tricks. I bought a bolt on flywheel lock and have many flywheel pullers.
If you can fit the puller between the gas tank and flywheel you can most likely do it.
Lots of room must remove oil lines to feed manifold and pump cable. A bolt on flywheel lock held the flywheel tight. Must raise front of engine because mounting bosses for motor mounts are casted into Mag cover. Used cherry picker and a strap. A standard 120 degree puller works fine. Thanks
