piston to cylinder clearance
  • piston to cylinder clearance
    what is the spec'd cylinder clearance for your SBT standard size piston for a yamaha 2004 xlt 800?
    Re: piston to cylinder clearance
    5 1/2 to 6 thou
      Is the .0055 to .006" total or per side? What do you recommend for the ring end gap?
        Total, 0.008- 0.020 should work fine, our spec for the piston to cylinder is larger than the o.e.
