Right now, I am in the process of installing a new engine in my Dura-Craft jetboat. The previous engine was a Tigershark 1000, but I am replacing it with a '06 Yamaha FX HO engine.
I've got my engine mounts and everything else fabricated, and I'm about to start on routing my hoses, control cables, and wiring.
But I need some help. I have a Clymer repair manual for this engine, as well as a Yamaha manual I downloaded, and yet, I'm still confused about thew wiring.
As the engine sits in the boat right now, I have 4 different sets of wires to hook up. One set is a 2-wire configuration, with blue and black. I know that this one goes to my fuel pump.
There is another 2 wire plug, with a black wire, with an orange stripe, and a blue wire with a red stripe. Not sure what this does?
There is a 3 wire plug, with a white with black stripe, a black with orange stripe, and a red with yellow stripe. As best as I can determine from the manual, this says it goes to a multifunction meter.
And finally, there is a 10 wire plug, and the manual does not show this plug configuration at all. The wires are as follows:
Green, brown, red, red w/yellow stripe, black, white, black w/orange stripe, pink w/white stripe, pink w/black stripe, and a blue w/white stripe.
As best as I can determine so far, the stop switch is comprised of the white and black wires. The kill switch uses the black, white, red, and brown wires. The starter switch uses the brown and red.
I also have the tachometer for the Yamaha HO engine, and I want to use that, and have it wired correctly for the oil and temp sensors.
I definitely need some help figuring this out. Any advice would be greatly appreciated! Thanks in advance.
