just recently did a sbt top end rebuild and carb rebuild. rear cylinder not firing at idle checked compression-ok checked spark-ok i think no fuel help
ls2000 jet boat rear carb no fuel
Re: ls2000 jet boat rear carb no fuel
If you think your not getting fuel to the rear cylinder then take the carb back off and go back through it.SBT Tech Support is here to help with your problems.
