Last summer bought a 2001 1200 XLT with seized engine. The oil line on the #3 cylinder had popped off which clearly had led to that that cylinder seizing. I rebuilt the top end with a complete SBT cylinder exchange, replaced all fuel lines, oil lines, oil line check valves, and rebuilt the carburetors. I ran it throuogh a meticulous break-in procedure and have put about 15-20 hours on it since break in. I checked plugs after every run and all indicated good mixture. Then the engine seized again. Initial inspection (looking at spark plugs and viewing piston head) indicated the #2 cylinder had seized this time and I feared oil starvation again. But after disassembly, I found that all oil lines were intact, oil was getting to the carbs and the cylinders appeared to be getting plenty of lubrication. However, the #2 piston had catastrophically failed and broken pieces of that piston were everywhere (in the cylinder, in the exhaust port, and in the crankcase.) I plan fix the ski again but don't want this to become a money pit..
Any ideas on what happened? Thoughts and recommendations appreciated.
Thanks!
Thanks!
