I have a blown motor in a 05 FX HO. It is totally detroyed - dropped a valve, ate up piston and head, broke a rod which busted the case and oil pan. I already had my repair facility submit pictures to SBT. Bottom line is I don't have a core.
Anyway, I have located a wrecked FX HO. I know that the engine itself will swap in. I also know that the ECU's for each year carry a different part number. Will the 05 ECU correctly control the 07 engine? A PWC dismanteller/salvage guy told me it would be best to switch out the ECU and wiring harness with the engine swap. Does this sound correct to those who work on these skis?
Thanks for your time.
- Bill
- Bill
