Just rebuilt the carbs (well one of the two) and I couldn't get the high and low speed adjustment screws to loosen up. The instructions that came with the mikuni rebuild kit said to take them out. Since they were not coming out I left them alone for fear of tearing them up and just went on with the rest of the steps for thr rebuild. Not removing those didn't hinder me with the rest of the rebuild. Was it ok to just leave them alone? If I wanted to remove them what is the best way to remove if they stuck?
The carbs are really nasty on the outside but looked good on the inside? After taking the carbs apart would it be ok to soak the carbs in something to try to get the gunk off the outside?
Also, if you have twin carbs, is the high speed adjustment screw on one carb and the low speed adjustment on the other?
