I have Yamaha FX140 2003 with 68hrs on it ! It has no any respond to start button no click! I can start the engine with hot wire among with pressing the start button but wont stay running, display showing no any issue. Recently changed the starter relay and fuel pump relay and still same problem!!! no clue what can be ..any help...thx
Yamaha fx140 2003 no respond no click
Re: Yamaha fx140 2003 no respond no click
Did you check fuses, if all is ok then you will have to start by tracing wires from the switch back to the E box, also make sure you have the starter relay wired correctly, wires to the correct posts, they may be filp flopped causing the issue, flip them around.SBT Tech Support is here to help with your problems.
