Have a pair of 96 wave venture 700's. Had to do a lot of work on one that was poorly maintained by previous owner. This season its down to the pump. I've currently got the shaft out right now and will be replacing the wear ring, but while i'm here I also wanted to replace the oil seal and bushing. Looking at the diagram, it looks like there is the spacer, then two oil seals, then the bushing. Could someone please give me some helpful information on how to remove these items? I've removed the spacer and can clearly see that the first seal needs to be replaced. Just don't know how to get them out, and I don't like to pry on aluminium.
On a side note to all this, there is quite a bit of marine grease in the shaft housing. Could someone let me know about how much grease is supposed to be in there for re-assembly?
Thanks in advance to any help given!
