Waverunner and Waveraider - low end hesitation
  • Waverunner and Waveraider - low end hesitation
    I acquired, through a trade, a 1998 Waverunner GP1200 and a 1996 1100 WaveRaider. I took them out at the end of the season last year and they both had low end hesitation. Once up on the water and higher RPM, no problems at all. I winterized them and used marine Stabil running through them and in the fuel tank. I will soon take them out of storage to ready for summer.
    I know this problem has been covered prior, but haven't seen an actual starting point. I would appreciate the forum's input as to what to look at first. I don't mind rebuilding the carbs, but that is 6 to take apart and reassemble. Just want to have a logical progression of where to start and what to consider here.
    BTW, compression is good and equal in all cylinders.
    Thanks in advance,
    B. Holt
    Re: Waverunner and Waveraider - low end hesitation
    The fuel system is the 1st place to start, go through the carbs, they should be inspected and cleaned every 2 yrs.
