Just bought and installed the top end kit that I purchased from SBT and have a couple questions:
1. What are the jug and head torque bolt specs?
2. I forgot to chamfer the ports as suggested befor assembly, is this a major issue?
3. What type of break-in do you suggest? Low rpm for a certain amount of time? Mix oil with gas
for the first tank at like a 60:1 ratio? What is standard?
Thanks for your help. The SBT products were perfect matches......
Craig
Craig
