Just installed s/b in this ski. Took it out last weekend and it ran ok for break in. Now, the ski will not get up on plane, as if starving for fuel. I have rebuilt the carbs (pop off in spec) and all seems to be ok. I isolated each carb outlet with a fuel line from each outlet into a catch tank. In all my (limited) experience, the fuel pumps should be putting out "gushes" of fuel. All three pumps barely push the fuel up the lines and trickle out into the can. Wondering if I should gut/cap sbn carb pumps and install remote pumps ones like I used to on the polaris ski's. Thoughts?
This is the 2nd s/b I have installed in this ski for lean condition. The last one I assumed had failed because of the pto seal came out and took a ride on the crank snout.
Anyone know if these yamahas have the same old probs the polaris' models had with poor fuel pumping and/or electrical probs with wires/boots?
FYI: CHECKED COMP AFTER PROB OCCURED 115ish on all three
