Just traded for this waverunner took it out for the first time, started overheating right away went into limp mode ido notice an exhaust leak inside the compartment any ideas on what to look at first
Overheating on a 1990 waverunner lx
Re: Overheating on a 1990 waverunner lx
It could be blocked cooling lines, fix the exhaust leak and blow air through all the cooling lines see if sand or shells are restricting the lines.SBT Tech Support is here to help with your problems.
