I purchased a 2001 xl800 that didn't run. I spary starter fluid in carbs and it will run.
I purchased rebuild kit and rebuilt the two carbs. mBoth carbs the filter were clogged and the carbs were gummed up.
I installed the carbs and I have the same problem. I blow in the lines and I can blow thru the lines. I removed the lines from the carbs and sucked gas from the vtank to the line.
I can not get the gas to pump thru the carbs.
I know the lines are correctly on the carbs.
What is wrong?
What is wrong?
