I just done a complete rebuild on my engine , I have everything hooked up but the exhaust system. I put a battery in and hit the start button and the only thing that happens is warning light comes on and it reads hi temp. I can here the computer clicking after I took the backing off ignition box. I was wondering if the hi temp light is on because the exhaust wire is not connected. Any ideas
2000 gp1200r electrical problems
Re: 2000 gp1200r electrical problems
Similar issue, I have actually replaced the starter, the solenoid-relay and the CDI. All I get is the temp and a the red light when I push to start. If I cross the relay with a screwdriver the starter engages beautifully. No response otherwise. Please help?
Ok, I put a new starter relay on and it fired up. If the temp light comes on I would also check the temp sensor on the exhaust pipe. Mine would not crank with the exhaust not connected (temp sensor) if that is bad the ski thinks the ski is over heated and will not start.
Mine is having the same issue. the 3 main connectors coming out the CDI(one being the d plate chip, one connected to the male counter part and the other just leftwith nothing plugged in) nothing seems to work. I have tried toubleshooting a few different things and nothing will get the tempsensor warning to turn off.
