Need some experienced advice. I am not familiar with 2 stroke engines, especially in Waverunners. Just bought 2 used Waverunners. I am having an issue with one where it will start(only with wide open throttle) and run(poorly) and the engine compartment fills with what seems like exhaust smoke. I cannot tell where the smoke is coming from.
I have already removed the exhaust joint and chamber assembly. They do not look cracked, not sure how to tell if the gaskets are bad visually. There is no soot around the joints. The rubber hose connecting the exhaust chamber to the water lock was tight.
The smoke seems like it is coming from the bottom of the engine or on the carburetor side of the engine. Any ideas how the exhaust could be escaping there or what to check? I read that the crank seal could be bad or the crankcase could have a hole in it. Not sure how that could leak exhaust though. I would think that only intake air mixed with fuel and oil would escape there. I am going to pull the engine tonight hopefully and see what I can find.
Also, when I was flushing water through it while the engine was running, the bilge filled up and turned black like it was mixing with oil. Engine did not try to cut off but I shut it off because it didn't look good.
