Totally confused here, in browsing the threads I see people state the stock pop off setting on this ski is around 75lbs, on the pdf file in the tech support section it says 45-55.
Why the differences?
This ski is bone stock with the exception of an aftermarket impeller, it has .25 over pistons installed.
Got 2 rebuild kits on the way, just want to make sure it is set right since the carbs are so easy to remove
Thank you!
.Thank you!
