Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    21,545
    Post Sea-Doo 4-TEC Codes
    Here is the list of trouble codes displayed on all Sea-Doo 4-stroke 4-TEC equiped skis. It will take a dealer and parts to cure most of these, but it at least gives you an indication of the fault, and sometimes you can replace the part yourself.
    P0106
    Manifold atmospheric presure sensor out of range
    P0107
    Manifold atmospheric presure sensor or Manifold barometric presure sensor shorted to ground
    P0108
    Manifold atmospheric presure sensor or Manifold barometric presure sensor shorted to 12V or open circuit
    P0111
    Intake manifold temp sensor faulty
    P0112
    Intake manifold shorted to ground
    P0113
    Intake manifold shorted to 12V or open circuit
    P0116
    Engine temp sensor faulty
    P0117
    Engine temp sensor shorted to ground
    P0118
    Engine temp sensor shorted to 12V or open circuit
    P0122
    TPS out of range - short to ground
    P0123
    TPS out of range - short to 12V or open circuit
    P01231
    Fuel pump shorted to ground or open circuit
    P0232
    Fuel pump shorted to 12V
    P0261
    #1 injector short to ground or open circuit
    P0262
    #1 injector shorted to 12V
    P0264
    #2 injector short to ground or open circuit
    P0265
    #2 injector shorted to 12V
    P0267
    #3 injector short to ground or open circuit
    P0268
    #3 injector shorted to 12V
    P0236
    Knock sensor out of range
    P0336
    Crank position sensor - wrong RPM detected
    P0337
    No CPS signal, but CAPS signal detected
    P0339
    Crank signal fault not plausible with cam signal
    P0344
    Cam phase sensor signal missing
    P0351
    Ignition coil #1 open circuit or shorted to ground or to 12V
    P0352
    Ignition coil #2 open circuit or shorted to ground or to 12V
    P0353
    Ignition coil #3 open circuit or shorted to ground or to 12V
    P0461
    Fuel level sensor circuit out of range
    P0462
    Fuel level sensor shorted to ground
    P0463
    Fuel level sensor circuit shorted to 12V or open circuit
    P0505
    DLA output stage cutoff memory cuircut or output stage fault or open circuit or short to 12V
    P0513
    Incorrect DESS key
    P0520
    Oil pressure switch faulty
    P0544
    Exhaust gas temperature sensor fautly
    P0545
    Exhaust gas temperature switch shorted to ground
    P0546
    Exhaust gas temperature switch shorted to 12V or open circuit
    P0562
    Battery voltage too low
    P0536
    Battery voltage too high
    P0600
    CAN communication problem detected by EMS or MPEM
    P0601
    TPS learns unlikely or checksum fault
    P0602
    ECU not coded
    P0604
    RAM faulty
    P0605
    EEPROM faulty
    P0605
    Checksum fault EEPROM
    P0608
    Sensor 5V power supply short to ground
    P0608
    Sensor 5V power supply short to 12V
    P0616
    Starter relay short to ground or open circuit
    P0617
    Starter relay short to 12V
    P1102
    TPS adaption failure
    P1104
    TPS adaption cancelled
    P1148
    Fuel injector 1,2 or 3 - safety fuel cutoff disabled
    P1200
    Blow-by valve shorted to ground or open circuit
    P1201
    Blow-by valve shorted to 12V
    P1202
    Oil tank pressure switch implausible or blow-by valve still closed
    P1517
    Compass out of range
    P1590
    VTS position sensor out of range
    P1591
    VTS position sensor - low voltage
    P1592
    VTS position sensor - high voltage
    P1593
    VTS malfunction
    P1607
    MPEM fault
    P1675
    Spare output 1 shorted to ground or open circuit
    P1676
    Spare output 1 shorted to 12V
    P1678
    Spare output 2 shorted to ground or open circuit
    P1679
    Spare output 2 shorted to 12V
    P1680
    Comminication problem detected by MPEM
    P1681
    Communication problem - instrument cluster message missing
    P1682
    Communication problem - EMS message missing
    P1683
    COM RAM fault
    P1690
    VTS control up circuit open circuit or shorted to ground
    P1691
    VTS control up circuit shorted to battery
    P1692
    VTS control down circuit open circuit or shorted to ground
    P1693
    VTS control down circuit shorted to battery
    P0344, P1200
    Burnt TOPS 10A fuse
    P1675
    Burnt depth gauge or spare 2A fuse
    P0353, P0267
    Burnt cylinder #3 ignition coil and injection 10A fuse
    P0352, P0264
    Burnt cylinder #2 ignition coil and injection 10A fuse
    P0351, P0261
    Burnt cylinder #1 ignition coil and injection 10A fuse
    P1680, P1681
    Burnt information center 1A fuse
    P0616
    Burnt Bilge pump, beeper, diagnostic center 3A fuse
    P1678
    Burnt spare 5A fuse
    P0231
    Burnt starter, fuel pump 10A fuse
    P0600
    Burnt MPEM 2A fuse
    P1690, P1692
    Burnt VTS 7.5A fuse
    Jun 2004
    PHILLY
    196
    Default Re: Sea-Doo 4-TEC Codes
    wow thats a huge help .. i was wondering where i could find that info for my rxp
    #*@* ME IF IM WRONG ... BUT HAVENT WE MET BEFORE?
    May 2002
    Michigan
    254
    You can check to see if you have any codes by putting the tether cap on, pushing the SET button 5 times and it should display them. Then use the mode switch to scroll thru the list, at the end of the list pushing the mode switch will end that function.
    When using BUDS it will give a detailed procedure for troubleshooting the code.
    21,545
    Even with the troubleshooting info, pretty much every fix requires the dealer anyway.
    Aug 2004
    San Jose
    2
    is there a way to clear the codes? can disconnecting the battery work?
    21,545
    Some codes need to be cleared by the dealer, it depends on the fault and repair. Do you have one showing?
    Aug 2004
    San Jose
    2
    no, I was just curious if no power to the computer would clear the memory, so you could see if the code is real or a glitch.
  8. #8
    21,545
    No, and there are no glitch codes.
  9. #9
    Jan 2004
    Brisbane, Australia
    12
    Is it possible to remove the Maintenance warning without using B.U.D.S?
    Colin
  10. #10
    21,545
    Only prior to 2003.
  1. The Sea Doo Squeal ???????
    By Mikegyvereast in forum Sea-Doo
    Last Post: 03-23-2021, 03:01 PM
  2. Replies: 14
    Last Post: 03-09-2010, 11:22 PM
  3. sea doo gtx 4 tec supercharged-engine error codes
    By Gavin Watts in forum Sea-Doo
    Last Post: 02-18-2008, 12:31 AM
  4. No Gauges On My 2003 Sea Doo Gtx 4 Tec
    By marinetech1 in forum Sea-Doo
    Last Post: 08-29-2007, 07:54 PM
  5. Sea doo 650 Cylinder Head on Sea doo 717
    By Joe Snuffy in forum Sea-Doo
    Last Post: 02-09-2005, 08:18 AM
