Questions about coverting to mix on a Ultra 150.
1. Does SBT have the Oil pump plate Kit for a Ultra 150 ? I see all the other Kawasaki models listed except the ultra 150.
2. What happens to the oil lines that don't go to the carbs when the kit gets installed ?
3. Is there any performace differance ?? The oil pump allows the mix to be adjusted depending on need so won't it run better with the pump ? If you idle a lot and the mix is for maximum protecting (Full Throttle) won't you foul plugs more often ?? I Ride hard and idle very little so it probably won't affect me.
I recently had a engine failure and I really like the idea of mixing to eliminate the complete oil injection system from causing problems (Pump , Lines, Fittings, Etc) if there is no performance problems.
Thanks
Thanks
