Me again :D Have some ?'s below, but first some pics.
Here's where I'm at so far with this thing:
![](http://www.zmydust.com/images/waverunner/disassembly/P1010248.JPG)
![](http://www.zmydust.com/images/waverunner/disassembly/P1010249.JPG)
![](http://www.zmydust.com/images/waverunner/disassembly/P1010239.JPG)
As for my questions, I ended up with a problem when popping off the throttle cable assembly from the intake manifold. The U shaped portion of the manifold snapped off. Looks like the front portion of the intake is extremely corroded and in very rough shape. Any idea what could have caused that extreme corrosion? The rest of it looks ok. Any thoughts aside from picking up a new (or used) intake manifold that would help to fix the throttle cable problem? Was going to try to work some JB Weld magic with the piece that broke off (if I can find it) and hope the throttle assembly washers can hold the thing in place.
![](http://www.zmydust.com/images/waverunner/disassembly/P1010243.JPG)
![](http://www.zmydust.com/images/waverunner/disassembly/P1010244.JPG)
