my seadoo xpl sucked in water through carbs cause exhaust gasket went so cleaned out cylinder and carbs, got going but now knocking noise from engine any ideas. still revs up just noisy
seadoo xpl noise
Re: seadoo xpl noise
cant tell you with out hearing it , then even you wont know 100% untill you take it apart . but i can promiss if its knocking it wont take long before somthing gives and 99% of 951s damage the case and or cyls when they go .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
Originally posted by 1fastski.comcant tell you with out hearing it , then even you wont know 100% untill you take it apart . but i can promiss if its knocking it wont take long before somthing gives and 99% of 951s damage the case and or cyls when they go .
