Bill got gauges fixed plug worked loose. Thanks for the info.
Ok on my carb problems. If I cut the gas off prior to shutting off the motor when I go to restart I cut the as on and hit the starter it fires up within 5 seconds. Leave the gabefore parking when I getit takes 20 +- sec to start.
When I checked carbs I didnt notice needles and seats leaking I had used same springs before the rebuild What do I need to do now change the needles and seats? Bought carb kits from SBT and changed everyting in carbs ended up putting old springs back in though.
