Ok. Mpem has tested out ok for ohm ranges. Have checked out everything else that I can think of and still lead back to bad mpem. Is this possible if it tests out ok? It seems to do everthing but send a signal to the starter solenoid.
Anything else anyone can think of would be appreciated since I am at my wits end.
I had this on my 95, you push the starter button, the gauge lights come on does a single beep and then it turns off, doesn't turn over or anything. I did the ohm tests from my clymers manaul and the MPEM was way off, but with the MPEM the only way to test it is with a new known good MPEM...I replaced the mpem and it's been working....
Thanks! The MPEM is the only thing I can keep going back to as being bad. Will have to break down and buy a new one. Learned a lesson buying a used MPEM.
