The driveshafts from any XP,SP, SPX, SPI, GT, GTX with a 580-657 engine will fit into the 1993 XP.
Any SD aluminum 140mm pump will fit. Plastic pumps require longer studs, but will fit too.
1993-4 was the last years they used aluminum pumps, and later models had plastic pumps.
Both are equal in performance. The best one is the one you have access to for the right price. But if you want to buy a new or good used pump, I'd go with the plastic pump with brass veins and 4 longer mounting studs to hold it in the hull.
was just asking because I have both one 94 xp and one 95 xp and i need to rebuild the 95 [the 94 will out run it ], prop is shot didn't know if I should switch to alum???
I have the following to part out.
complete with titles
92 spi runs.
93 sp SBT motor needs Rotery valve gear.
92 xp New crank in bag, new pistons in box all 587 motors.
make offers
Reason: 587
NO I'm not wanting to put a alum prop in , I was asking because I see alot of pumps on e-bay ready to go but if plastic is the one to have thats the one it will be I will rebuild mine . so I'm in the market for a prop ,wear ring and seals? . are these parts I can get from you ?:emoticont
