93 Xp
  • 93 Xp
    does anyone know if there are any other xp years other then a 93 that i can use for driveline parts.
    thanks
    brad
    Re: 93 Xp
    The driveshafts from any XP,SP, SPX, SPI, GT, GTX with a 580-657 engine will fit into the 1993 XP.
    Any SD aluminum 140mm pump will fit. Plastic pumps require longer studs, but will fit too.
    1993-4 was the last years they used aluminum pumps, and later models had plastic pumps.
    Bill O'Neal <br>
      Re: 93 Xp
      thanks
        Re: 93 Xp
        which pump is better ,plastic or alum:emoticons
          Re: 93 Xp
          Both are equal in performance. The best one is the one you have access to for the right price. But if you want to buy a new or good used pump, I'd go with the plastic pump with brass veins and 4 longer mounting studs to hold it in the hull.
          Bill O'Neal <br>
            Re: 93 Xp
            was just asking because I have both one 94 xp and one 95 xp and i need to rebuild the 95 [the 94 will out run it ], prop is shot didn't know if I should switch to alum???
              Re: 93 Xp
              I have the following to part out.
              complete with titles
              92 spi runs.
              93 sp SBT motor needs Rotery valve gear.
              92 xp New crank in bag, new pistons in box all 587 motors.
              make offers
                Re: 93 Xp
                The 1995 model XP has a plastic/bronze pump and a stainless steel impellor.
                I may be confused, but are you asking if you should install an aluminum impellor? If so, no way! An aluminum pump? No way!
                The 1995 needs a plastic pump and a stainless impellor, or you will be degrading your ski.
                Bill O'Neal <br>
                  Re: 93 Xp
                  NO I'm not wanting to put a alum prop in , I was asking because I see alot of pumps on e-bay ready to go but if plastic is the one to have thats the one it will be I will rebuild mine . so I'm in the market for a prop ,wear ring and seals? . are these parts I can get from you ?:emoticont
                    Re: 93 Xp
                    Yes, I have all of that stuff.
                    Bill O'Neal <br>
                      Re: 93 Xp
                      e-mail me a price for prop,wear ring , seals and any thing you think I might to rebuild my pump including shipping to 43055 :emoticont
                      • #12
                        Re: 93 Xp
                        $185.00 will buy you a new wear ring, seal, oring and a refurbished stainless steel impellor and shipping costs.
                        To order, call 626 914 9509 with a credit card.
                        Bill O'Neal <br>
                        • #13
                          Skiguy
                          Skiguy,
                          E-mail me @ skooter81@aol.com.... I'm interested in the 92 SPI..
                          Thanks,
                          Skooter
