coils tested good donst beep with key tried 97 gsx box and key got it to beep but still no spark im awhare it may be the brain but need to eliminate the pick up before i invest in box
i looking for info on testing the crank ignition pick up or trigger . i need to know what pins to test or the wires colors and any test specs... i know where the lead is just need any info on this test
also does the 97 gsx mpem or brain work in this model i know it would need to be programed but i have a kety and brain from a 97
thank you
thank you
