Hi i have a 95 hx with a 657x does anyone know the torque specs for the 13 and 11mm hex head and allen head crankcase bolts? thanks.
Crankcase torque specs
Re: Crankcase torque specs
hyper....
www.seadoomanuals.net
considering your inner crank issue, and additional questions, a free manual is the most important tool in your shop!!
The 13mm is 30 ft lbs
The 11mm is 17 ft lbs
the hex is 17 ft lbs
PS - Also... you SURE you have a 657x?? The HX never came with a 657x.. 717's only..Dan Solie -
That still doesn't mean it's a 657.. The cover's interchange....
Still strange though, it may BE a 657x.. But those never came stock in an HX..
Since you need to torque specs.. I assume the motor is apart?? What is written on the top of the pistons?Dan Solie -
