Oil for balance shaft
  • Oil for balance shaft
    How much oil goes into the balance shaft? (New/rebuilt SBT motor) 01 LRV 951 motor. thanks.
    Re: Oil for balance shaft
    40 ml (1.35 oz) motor oil SAE 30w. Sound right?
      SBT's don't come with the oil already in? But yes, you can use 30w...
      Dan Solie -
      04 RXP (the "Instigator")
      94 xp (freestyle mods)
      95 xp (faster than the 94)
        The SBT engine will have oil in it from the factory.
          BUT, it sure is a good idea to check it and make sure!
          John Kubiak
          Las Vegas, Nevada
          Sea-Doo Tech 13736
            I have a 93 4.3 CPI Vin W I am working through some engine trouble as most of you know and am buying a replacement oil pump. I know that I dont need a high volume one but every part store I look at offers a 3/4" and a 5/8" shaft. How do I know which one I should have? Thanks
              Did you know this is a PWC forum?
              No known PWC uses a GM 4.3 litre V-6 Central Port Injection engine!
              However, the 5/8" and 3/4" measurement you are referring to is not shaft size, it is the inside diameter of the oil pump inlet, and corresponds to the outside diameter of the oil pump pick-up assembly (also called oil pump screen). Measure the Outside diameter of your pick-up to determine which one your engine currently has. Both the oil pump and the pick-up are readily available in 5/8" and 3/4" sizes. There should be no problems locating both new parts for your specific needs.
              John Kubiak
              Las Vegas, Nevada
              Sea-Doo Tech 13736
                Mr. Smarty pants.... :)
                Dan Solie -
