so I took the boat out on Saturday and after running pretty light for about an hour (15 mph with a tube and little kids on the back) one of the engines froze up on me. When I got home, I pulled the head and found one of the pistons is beat up. I was able to get the engine to turn over fine after spraying lube in there, but have little to no compression in that cylinder. What can I do to get this fixed? Can I replace the rings to get compression back? Should I replace the piston and rings? Pretty sure the carbs need cleaning/rebuild. Any help is greatly appreciated. Pretty new to this, so learning as I go (and as I make mistakes)
Challenger 1800 - 787 engine problems
Re: Challenger 1800 - 787 engine problems
Pull the cylinders and see what the crank looks like too. If the crank is in good shape then maybe do a cylinder exchange kit and rebuild your carbs.SBT Tech Support is here to help with your problems.
Are you suggesting a whole top end rebuild? Or can I replace just the piston and rings? I will take off the cylinder tonight and take a look at the crank, hoping it looks OK since it turns freely and is not making any grinding or banging sounds.
it will need to be bored out dont just do the piston and rings, it will not lastSBT Tech Support is here to help with your problems.
OK, so I pulled the carbs tonight and will pull the exhaust tomorrow so I can get the cylinder off to inspect. I did stick my finger down into the rotary valve whole and felt around a bit. I do have a little bit of metal shavings from the top of the piston down there... am I better off with a whole new engine?? Don't have the cash right now, looking for the most economical fix. Can I pull the piston and cylinder and take it to a shop to make a "band aid" and get it running.
It’s really not a good idea to just bore one cylinder and if the crank has metal shavings on it from the top end failure, you will need to remove it and clean and inspect it. If you band aid it back together it may fail and destroy the case or other expensive parts.SBT Tech Support is here to help with your problems.
