Okay, I'm getting closer to firing-up the new SBT 587 engine I ordered. I ordered and installed a block-off kit, too. I want to be sure I've got the right oil arrangement.
I bought a half gallon of Bombardier Formula XPS2 Synthetic Injection oil to put into the oil tank to circulate through the modified system. I understand this oil should be changed once per year. Is this the right oil and changing frequency?
I plan to use the SBT break-in oil as pre-mix based on the mixing formula on the back of the bottle until it's used-up. Is this correct?
After the break-in oil is used-up, what should I use for pre-mix?
