05 RXP using oil
  • 05 RXP using oil
    Hi all, newbie here. I bought used a 2005 RXP with SBT rebuild motor in it last year. 120 hrs on the clock, about 50 or 60 on the motor. It runs great but uses about 1/2 qt of oil per tank of gas. No leaks, no smoke and I don't smell burning oil. Plugs look perfect, very light tan. What have you guys seen, rings, valve seals? I havent done a leak down or compression test yet, just lookin for easy answers. Any help would be great
    Re: 05 RXP using oil
    It could have carbon build up on one of the rings, try some ring free in the fuel.
      OK I'll give it try. Any particular brand you've used?
      Thanks for the help.
        Yamaha make a good ring free.
