While I am waiting for the UPS man to deliver my SBT engine I thought of going thru the carb. what is the factory settings for the carb?
94 Montego 640
This might sound like a silly question, but please be gentle as this is my first time with a tiger shark. No High side adjustment? At one time I could boast that I only did Yamahas, well I lost that right as of this one engine. Man, the engines are very very similar in fact the intake is the same as the 62T. I would guess to say Suzuky did a little industrial espionage before manufacturing their engine.
Your carb has a high speed and a low speed adjustment. The low speed is the one closest to the engine and has a T handle on it. The high speed screw is the one furthest from the motor and has a limiter cap on it that must be removed before you can adjust it.
Okay then...this is right out of my 97 640 service manual and my sister had a 95 640 and it was the same motor and carb on that one so here goes..."remove the limiter cap from the low speed mixture screw. Carefully rotate the the low speed screw clockwise until lightly seated, then turn counter clockwise 7/8. attach flush kit start engine, turn water on, and allow engine to reach normal operating temp. rotate low speed screw clockwise or counter clockwise until engine idles smoothly and quickly responds to to throttle lever movement. install limiter cap with tab centered between stops." Sorry it gives no specifacation for the high speed screw.
Well I'm a bit confused. This boat has a Carb that has both a high and low setting (adjustment screws) . I have set the low (next to the throttle mechanisign to 7/8) The high was at two full trun's is this correct? my YAMAHA Manaul say's that some 650 are between 1 1/4 to 1 3/4 so i have it set at 1 1/2. If you ask why read my second post on corporate espinage. I do feel there is some serious dubbing going on here so I think (correct me if I am wrong) but the high setting will be very very close. The engine has come in so I really need the correct settings as I do not want to blow an engine during the break in.
