Would stock Mikuni Super BN 44s work as replacements for the OEM Mikuni carbs? They are much less expensive and the only difference I can see is the fuel inlets and returns must be modified with tees since the fuel fittings on the carb body only allow for a single in and out. Since the fuel is under pressure it shouldn't matter if there is an external tee vs. one incorporated into the carb?
I tested the pop off on one and it was 10. A bit low? Would I get dribbling with the heavy idle of this PWC?
