I bought my ski used. if you start it up it runs for about 5 seconds the shuts off. If you dis connect the battery the re connect the battery and try to start it again it will run for 5 more seconds then shut off.I found that if the wires that lead to the guags are un plugged and reversed the ski truns great but the guages are not working at all. If you push the code button it asks for a code? Is there a factory default code? Do you guys have any thoughts??????
GP 1200 guages not working
Re: GP 1200 guages not working
You have to reset the code if you do not know it. If you open the front hatch there is a single blue wire. Disconnect single blue wire going to guage and hold mode button down until four blank spaces show up and enter new code.....
Hope this helps
CODE?????????????? I just got a gp1200r, is there some sort of code system to lock the ski???Originally posted by dtd696You have to reset the code if you do not know it. If you open the front hatch there is a single blue wire. Disconnect single blue wire going to guage and hold mode button down until four blank spaces show up and enter new code.....
Hope this helps
Thanks!
Brandon
My '99 GP1200 has a "lock" and "start" mode. If you hit the mode button you can change it from start to lock and have to enter a pre-programmed code to unlock it. I thought that 98 and up had this security feature onthe GPs. Hopefully others more in the know on this forum will chime in here.
Lookin at the owners manuals they stopped in 99 =/ 00-03 are diff, no lockout and far less features on the cluster, the old ones had a oil level gauge, clock, lockout and a few other features. it SUCKS they took those out, a clock would be awesome as well as a real oil gauge My guess since its quote a 'race' ski they felt those were fluffy options they could delete and pocket the money on =/ Shame the other cluster wouldnt work in mine as i would change it in a heartbeat...
B
yea mine did some weird stuff like that after i had the battery/engine out. It would start once without putting in a code, after that it had to be unlocked or battery unplugged/reconnected. I can't remember, but I don't think the gauges worked right until it was unlocked.
