Is there supposed the be a restricter in the fuel return line to control the pressure. Thought I read that there was a recall about this . Just want to check if I need this .
Thanks for the informative site.
what ski? if its a raider 1100 not necerarily. there was a recall. not all raider 1100 were taken in for the recall so somehave the recall some dont
Rob
pull the fuel line return hose off at the cyl#1 carb and look at the tube it slids onto...should be blocked with a pinhole in it..if it's wide open like the fuel inlet line then you don't have the upgrade. Not a recall , just a TSB...but important to prevent lean siezure etc.
Dav_
to tell you the truth it is a recall/update. i had my update done at the dealer and yamaha paid for it. I got a letter in the mail stating it is a recall/update. There is also another thing thats for water splashing. the dealer will add these 2 pieces of fiberglass bubbles to the bottom of the hull to stop it from splashing. its riveted in the hull so thats why I didnt want it done. as far as im concerned if it was caled back by Yamaha and they paid for it than its a recall in my opinion
Rob
Oh no problem dudei figure since yamaha is picking up the tab than it has to be a factory recall. on updates it comes out of our pocket
Rob
i would go to the dealer and tell them about the recall and see if yamaha will puick up the tab. they should since its a recall and there is no time limit on the recall
