CaptToyota ,
today I did the factory setting,
the results are not good
when I start the idle is a little bit too high, and when i accelerate the engine chokes itself
sometimes it leaves and then when it reaches the high rpm it seems run well
I went up to 60 mph on the speedo.
must I increase the low of 1/4?
can you give me your opinion?
the old set was around 1 and 3/8 and it run not so bad but it seems it didn't run too bad but the high rpm didn't seem to give the whole power. and the idle was good.
[img]ftp://pascal.weydmann@ftpperso.free.fr/jet/VENTUR01.jpg[/img]
hey Hal,
i have the same settings in my 97 book, but my pocket spec book, LIT-18571-SD-98 printed may 1998, shows diff settings for the 96..it shows:
5/8 (F,R);3/4(C);+-1/4 on all highs
1-3/8 +-1/4 on all lows
Same 75pilot, but 107.5(F,R);95(C)mains...same n/s=1.2
I would think service manual would be more accurate . Does the service manual show 95 center carb main? (don't wanna go out to the car and look for myself- LOL).
btw Hal, with your current setup what are your adjusters set at..getting ready to dial in my venture on friday.
