I am working on a friends 2003 XLT 1200 that had the exhaust and carbs removed at a dealer's shop and I am in the process of re-assembling after replacing the reeds and rebuilding the carbs.
The cable that goes from the oil pump to the carbs will not reach the carbs and I don't know why? The mounting nuts will reach the mounting bracket just fine. The cable had been removed at the carb but was not removed at the oil pump. Do I have to pull harder on the cable to get it to connect at the carb end or is something wrong?
Thanks, Mark
Thanks, Mark
