I just finished replacing a 760 waveraider motor, and during one of the first steps to reassembly I ran into a problem. The threaded mounting hole for the bottom starter bolt was too large! I wasn't able to determine if it was stripped out or actually drilled bigger and re-tapped. In any case I had to go out and find a longer bolt with a nut and lockwasher to back it up. Is this normal?
replacement block difference
There are two starter mounting bolts and I am talking about the lower one. The bolt is supposed to screw into a cast ear off the motor casing. That cast ear was tapped with the incorrect size hole (too large) for the M8 bolt. I had to go out and get a longer M8 bolt so that the threads would go all the way through the ear, and be secured by a nut on the other side. Will this "accident" come into consideration on the cost of the motor?
OK, I understand now.
No that doesn't effect the price of the engine, it's a warranty issue. I can however compensate you for the parts you had to purchase, just fax me the receipt and I'll send you a check.
In the future please call in with these issues, I need to authorize field repairs up front.
[ September 20, 2002, 10:56 AM: Message edited by: Bryan Glynn ]
