Tachometer
This topic is closed.
  • Tachometer
    I have a 2000 Yamaha ls2000 and one of the tachometers does not work. Is there a fuse or an easy way to fix this? The tac worked until just recently.
    Re: Tachometer
    i'm a watercraft tech at a dealership and i have replaced quite a few tachs for no apparent reason. you should make the proper checks and make sure that it is the tach though. i would first recommend you switch out tach from the other side to see if it works. it is fairly easy and doesn't take a lot of time.
      Re: Tachometer
      Thank you - SBT Mgt.
