i'm a watercraft tech at a dealership and i have replaced quite a few tachs for no apparent reason. you should make the proper checks and make sure that it is the tach though. i would first recommend you switch out tach from the other side to see if it works. it is fairly easy and doesn't take a lot of time.
Thank you - SBT Mgt.
