I have an '06 VX110. Upon startup for the year, it ran fro about a minute and then quit. I pulled off the seat and there was a water/oil mix in the bilge. There was the same mix in the airbox. I pulled the plugs and when I turned it over, the same mix shot out. Evidently, it is cracked somewhere. I have winterized them myself since new. It was stored on a lift over the winter, and in January the lift lost air and the waverunner sat in the water, and the water froze. i don't think that any water got up into the engine, but who knows? On the lift, the waverunner does not sit level, but sits at an angle that makes it "nose high" so that water will flow off of the floorboards after use. Could it be that with this angle not all of the water got expelled when I was winterizing? Where would a guy start as far as troubleshooting where the breach is?
Thanks!
Thanks!
