Have a completely stock xl 700. Wouldn't start, installed new fuel filter, still no start. New NGK factory spec plugs good. Blew, by mouth(using clean tube) through "out fuel line" heard bubles in tank. After this fuel began to flow to filter very well. Connected fuel line on both sides of filter. Started engine and it instantly went to top RPM. I shut it down immediately. Tried 3 more times, same thing. Throttle cable functions smoothly when engine is off. Butterflies move as they should. Did I blow too much pressure back into tank and rupture something?
Any help is appreciated. Thanks!!
